Dr. Geddes SPEAK speaker design software
Right now my biggest interest is PA sub design and build.
i am still at level 1 of 10 design wise and woodskills wise, but i want to learn to make some sawdust and use REW to measure the response
of the cabinet vs the predicted simulation response in hornresp
Reactions: GM
I hope you did find your way to this subforum: https://www.diyaudio.com/community/forums/subwoofers.63/
Or, maybe more appropriate if I link that same forum filtered by the number of views:
https://www.diyaudio.com/community/forums/subwoofers.63/?order=view_count&direction=desc
That way You'll notice the Tapped Horn (or TH) rising to the top, a subwooferdesig by Mr. Tom Danley for PA purposes.
Mr. Danley is a designer for https://www.danleysoundlabs.com/ and his subs, as well as his Synergy/Unity horns are quite popular here as inspiration for DIY projects.
Mr. Danley isn't that active right now and hasn't logged on in quite a while, but he has shared a lot of his views and inventions on here.
Personally I think he's brilliant.
Hey all,
I've been experimenting with SPEAK, but am having a terrible time. There are numerous notifications about not being able to save, and yet somehow if I hit Exit, once in a while it saves something. I managed to get a new driver with parameters saved and a new enclosure... but nothing changes in the Plot window (even after clicking on the Update button). I managed to save a project, but I can no longer do that. It seems that all I can do is see the Default Plots.
Now I'm getting "Record is locked" in the Enclosure parameters window. And a "Sub 1 - Bad data description for the front acoustic lever" notification when trying to Update the Plot.
I'm rather frustrated 😕
If there are any pointers, I'd really appreciate it!
P.S. I realize Dr. Geddes is on the forum, but he's acknowledged that he doesn't support the software by offering it for free. Hoping to find another DIYer to help in the meantime.
No, @diyiggy . Vituixcad is not capable of doing the things Speak can.
@Tieftoener this sounds like a Windows problem. Maybe due to changes over time, the original API doesn't support the current permissions scheme or directory structure, I don't know. Your best information might come from Dr Geddes himself. At the least find out what the API was and research using it on your current system. If you're lucky Dr Geddes might have a recommendation for doing this, but I wouldn't guarantee it given the way things can change.
Reactions: Tieftoener
Hey all,
Would be neat to see if someone could build an acoustic lever. I'm not aware of anyone who has, except Geddes.
