Simple HT voltage regulator
I am trying to generate about 350V from 420V unregulated - about 50ma. The regulation for this design is not the best - I was wondering if it could be improved or other ideas welcome.
I am liking the TL783 it needs a zener to protect it so no current limit but I don't think that's an issue. From #8 wonder if you can do something clever with the TL431. Avoiding large voltage zeners as the temperature coefficient is large.
I misread the original schematic. At first glance I assumed TL431 was being used as part of the diff-amp, not the reference for it. I would think a different circuit using the TL431 as both diff amp and reference would be superior.
Some ideas:
These are probably overkill:
https://www.diyaudio.com/community/threads/a-commodity-based-hv-regulator-flexhv.344887/post-5966123
https://www.diyaudio.com/community/...istors-for-450v-reference.242624/post-5962982
These are simpler:
https://www.diyaudio.com/community/threads/simple-hv-series-regulators.198986/post-2753552
A negative one, but if the input is floating, it doesn't matter:
https://www.diyaudio.com/community/...voltage-regulator-circuit.180140/post-2417349
They have the advantadge of being referenced to a single rail, which limits the risks of failure and only require low-voltage parts. The ballast transistor is the only HV comonent
IMO the OPs regulater cct in Post #1 is overkill if it is for a vacuum tube amp.
A simple emitter follower controlled by a Zener limited RC ramp is plenty.
I used this on my verse of Norman Crowhurst's Twin Coupled Amp.
In drops the B+ to were it is required, it doesn't need to be variable.
The regulater section is the upper RHS of the schematic. Two FETs for safety.
The rest is obvious & gets a B- to run the tails on the differential front end of the amp, Etc.🙂
kodabmx,
You suggested the TL783. Good idea.
But your schematic had 400V in and 350V out into a 50mA load. It claimed that the dissipation in the part was only 845mW. ?
560 Ohms x 0.05A = 28V.
400V - 28V = 372V.
The TL783 has to drop an additional 22V, in order to get 350V out.
22V x 0.05A = 1.1 Watts dissipated in the TL783 dropping active device.
But the OP voltage was 430V, not 400V.
The additional 30V and 0.05A will require an additional 30V / 0.05A = 600 Ohm resistor.
560 Ohms + 600 Ohms = 1160 Ohms.
That way, the TL783 will still only have to dissipate 1.1 Watts.
