American Bass 500.1
I will have to get back to you later tonight or tomorrow to check to see if I get a clean ground and no dc .
I’m removing the power supply fets right now and cleaning the board since this was someone else’s repair at some point in time and the did a horrible job at soldering .
Here are some photos of the board .
Also here is the drive on 2 banks of fets . Something isn’t correct since it looks like the bottom of the waveform is not being pulled back to ground .
Any ideas what might cause this ?
Scope set to 5us 2volts/div
The trace was centered on the reference line before looking at the drive
I don't know a lot about diagnosing bad boards but I know that what I'm looking at has likely more then one problem and a few more ready to happen once the current problems are fixed. That board looks worse then the old Hiphonics boards of the late 80's early 90's. Decent designs but no QC. But this board doesn't even look like a good design. Those transformers are a likely problem, especially on the output side. I bet there is a short in one of them. Do they move around on the board? They aren't held down for beans and by looking at the pics this board doesn't even have any support for the center of the board anywhere near those heavy components. That thing is flexing and vibrating all over the place and that hot melt glue they set the transformers in is not likely doing much. Plus it looks like there is a lot of bad soldering going on on that board. Those no name 85 degree caps that are surrounded by heat sources are likely put well above 85 degrees during hard operation. They have a bank of FETS on one side and transformers on the other side and that 85 degree rating is to low. I bet the specs on those caps shift when in hard use. If you ask me that amp isn't even worth fixing.
Without a loading cap I get good drive signal on all of the gate pads for the fets .
With a loading cap I get the same triangle wave on all of the gate pads . With it removed I get a good squarewave signal on all of the gate pads . Both sides of the resistor .
The issue is the amp will draw excessive current with the fets installed
