Strange input stage/phase inverter
Joined 2021
Hello!
I have seen the following circuit in "Acrosound_Ultra-Linear_Transformers_1955_gc.pdf" as part of a 100W PP amp example. What are the advantages (if any) against a more conventional one?
Simulation works. There is a balancing resistor between R4 and R3, omitted for simplicity.
Thank you!
Jose
Originally used in oscilloscopes, this is a cross-coupled phase inverter, also used by Audio Research
as a balanced driver stage (with cathode follower outputs and current source load) in their earlier amplifiers.
  • Thank You
Reactions: PRR and jcalvarez
Every tube-geek should sleep on copies of Radiotron Designer's Handbook. The small black edition in even years, the big red edition in odd years. RDH answers most all basic test and topology questions.
The 3rd has all you really need but the 4th has the wonky stuff. In the 4th (red), "Exciting push-pull amplifiers" starts page 521. The Van Scoyoc is mentioned as a footnote to page 527, note C25. Sadly it is not in the general Radio-News but a supplement for selected readers.
  • Thank You
Reactions: huggygood
