I am looking for a tip for this pencil iron. It is a 110volt pencil not the low voltage version. No model number just the name and 10 watt on the handle. Lost the original tip. Bought in the 60-70s.
Any ideas anyone?
Any ideas anyone?
Dave you might do better using the name ORYX to search. Bits are very difficult to get now, though some do come up.
(I believe Oryx went out of business several years ago.) Not sure what type of bit yours takes, but if it is a screw on type you need the washer too or the iron will over heat...
Alan
Alan
Thanks Alan,Dave you might do better using the name ORYX to search. Bits are very difficult to get now, though some do come up.
Alan
It used to slide over the shank and had a friction ring to hold it if memory serves me correctly. I will continue to search.
