Onyx 10 watt soldering pencil
Dave you might do better using the name ORYX to search. Bits are very difficult to get now, though some do come up.
(I believe Oryx went out of business several years ago.) Not sure what type of bit yours takes, but if it is a screw on type you need the washer too or the iron will over heat...
Alan
Alan
Thanks Alan,
It used to slide over the shank and had a friction ring to hold it if memory serves me correctly. I will continue to search.
