Convert a PAS3 to a PAS3x with tone controls that are out of the circuit when centered
Does anyone know of a mod, what parts would be needed or how you could convert a PAS3 to a PAS3x with tone controls that are out of the circcuit when centered? Or... possibly the instructions/schematic for adding a switch that would simply bypass the tone controls when not needed?
Thanks in advance.
Does anyone know of a mod, what parts would be needed or how you could convert a PAS3 to a PAS3x with tone controls that are out of the circuit when centered? Or... possibly the instructions/schematic for adding a switch that would simply bypass the tone controls when not needed?
The PAS-3X used special mono pots that either had an open circuit in the middle (treble), or else had two wipers (bass).
However, the entire PAS-3 tone circuit can easily be permanently removed.
