Spectral DMA-90 questions...
Hello all,
Read up on the Spectral DMA-90 requiring special cables to prevent oscillation and frying the output devices...can anyone confirm this to be true? I remember some of the the Naim amps needing special speaker cables, as these cables completed the Zobel circuit (?).
Anyway, if so, can anyone offer up the impedance / inductance / capacitance of the "correct" speaker cables? Would it be worthwhile to try to "match" (as best as I can) these parameters for safe operation of the amp?
If you have cables with a low characteristic impedance then you want to consider a Zobel network at the speaker end. Typical values are 10 Ohms in series with .1 uF. This damps out high frequencies reflected back to the amplifier.
Ha, how often does a one of my questions get answered by an Audio Legend...sorry, no offense adason 🙂
My Quad ESL-2805 appears to have a Zobel already...
EDIT - whoops, thats not a Zobel...in parallel, and not across the outputs
EDIT EDIT - a pic of outputs with coil / resistor across output...doesn't this serve same purpose as Zobel, preventing reflected HF back to amp?
Matthew Polk (a familiar name to diyAudio readers of a certain age) patented this Zobel network decades ago -- the patent expired pre-Y2K. He recommended 6.2 ohms in series with 0.05 microfarads. Images below.
_
