TDA7293 project
Good evening gents,
Apologies, posted initially in the wrong place - will get the hang of things.
I'm laid up, no driving licence for 'dicky ticker' reasons' from October so I'm crawling up the walls. I have a weeks holiday at Christmas so I thought I'd get on with an audio project. I have a Rega record deck gathering dust on top of the wardrobe I thought I'd have a go at building an amp, not from discrete components I hasten to add. I've spotted the TDA7293 which seems ideal as a basis for this and studied the data sheet which has a couple of example circuits one of which is described as a TDA7293 block diagram. This diagram appears to relate to a PCB layout and is quite straightforward ie few components.. Is this a working circuit, I thought I'd knock it up over Christmas well at least the PCB. There are a couple of other circuits (modular and high efficiency) which are also on my radar although the component count of one is far higher. What are peoples thoughts on the circuit I should go for. Thanks in advance.
Trying to find reputable source for 2 TDAs here in the USA.
Good luck. I have a source but I have to buy 10 for $42. I only need one for my guitar amp. I asked around if I could sell some, but no response. I guess I will get them. Cheaper then getting another guitar amp.
Mouser has 8,000 on order, Rd no, Digi-Key no. I will Not use EBay. I only want to replace this ONCE. I will tear up a PCB getting one off.
RS not RD. DK expecting them 7/22.
You could buy them, keep what you need and maybe a spare then sell rest on ebay.
