2SC5200+2SC1943 on 25volt Split Supply?
i was asking if 2SC5200 and 2SC1943 can handle my 25 volt split power supply
its for my amplifier i'm going to buy soon for $10 or (501 Philippine Pesos)
and i have a 20v~0~20v transformer peaked at +25v 0 -25v non regulated
the transformer has 2 secondaries (1 secondary that is center tapped)
Power supply - +25v 0 -25v 3 amperes
Amplifier - 2SC5200+2SC1943 100-150 watts @ 4 Ohms
Speaker - 2x Konzert SG-6W 150-200 watts @ 8 Ohm
i was gonna parallel the speaker for 4 Ohm Load when i bought the amplifier
i was also wondering how many watts of output at 25 volt dual power supply
here is couple of examples of amplifiers based on C5200 and A1943, running on +/-70 and +/-80 volts, multiple parallel outputs, and bridged amps up to 2000 watts
btw, there is not such thing as 2SC1943
2x20VAC can be up to +-30V depending on the transformer.
Have a look at the datasheet for the SOA:
see post 3580 here:
NAP-140 Clone Amp Kit on Ebay
At +-30V you have about 5A max. continuous current which is fine even into 4Ohm loads for a single output pair.
At +-70V the transistors only have about 1A max. continuous current so you are looking into paralleling many many pairs for 4Ohms load or better yet choose other transistors with higher SOA.
Full output swing depends on the amplifier also but at +-25V I´d expect about 35W into 8Ohms at least. (~21.5Vp output swing)
I personally wouldn´t use the 3rd schematic shown by adason.
Not into 4Ohms at full swing. The transistors will be well past their SOA.
They might survive with the right music and a little bit of luck though ;-)
A 20-0-20 3 amp transformer won’t have any trouble powering an amplifier with a 4 ohm load. Expect about 48 watts out In The Real World. About 70 watts of power draw, and 116 VA from the transformer. That assumes a continuous sine wave load. Music draws about 1/2 of that, even when turned up to gross distortion.
