Soundstream BXA1-10000D
Sorry forgot to add photos
+12V: -112.8
+ Low: -6.11
SW: -6.15
-Low:-125.8
-VCC:-125.6
Gnd: -6.40
ST:-4.33
Mute:-120.2
+5: -121.2
-VCC:-126.0
Gnd:-6.51
IN:-6.80
This is what I get on the pins of the audio driverboard using amps ground terminal as reference.
There are no components on the back of the audio driver board
There will be voltages that are near ground (within ±20v). Those are referenced to the secondary ground (which is currently tied to the primary ground).
The voltages that are near the negative rail are referenced to the negative rail so you have to use the negative rail as the reference.
+12V:-12.03 Negative rail as reference
+low:125.1. Negative rail as reference
SW: 124.9. Negative rail as reference
-LO:-125.6. Amps ground terminal as reference
-VCC-125.4. Amps ground terminal as reference
Gnd:0.00. Ground terminal as reference
ST: 127.2. Negative rail
Mute:5.40 Negative rail
+5:4.90. Negative rail
-VCC:-125.0. Negative rail
ST:125.7. Ground terminal
Hope this makes sense
If you need a specific pin on a different ground point let
Me know and I will re measure
Wondering if I can ask for a lil help with this amp .
I’m learning as I go
There are 12 pins on the audio driverboard .
Which ones need to be referenced to secondary ground and what pins need to be referenced to negative rail ?
Pins are as followed
+12
+LO
SW
-LO
-VCC
GND
ST
Mute
+5
-VCC
GND
IN
