Highest power supply for a dual TPA3116D2 amp
I want to buy the 2021 Nobsound NS-15G TPA3116 amp but i do want 2x100 watt in 4 ohm or close to that since most class d amps has a max power rated at 10% thd, what is the highest i can go for, i know smsl make a 24 volt 6.75 a and nobousound a 24 6a power adapter,supply, is that enough ?
I need a good but cheep input selector (rca) for 4 units, i don't want the cheapest like this, don't like the size,shape of it, anything that can be recomended TronicXL Analogue Stereo 4-Way Input Audio Switch 3x 2x RCA Female 2x RCA Switch Switch Input Soft 1 Output 3 Input Audio Switch Loudspeaker Boxes HiFi: Amazon.de: Electronics & Photo
From TI datasheet:
Any claim beyond that is marketing fantasy.
Your 24V supplies are fine, but expect 2 x 30W and will only drive 8 ohm loads.
That at 10% distortion.1 Features
1• Supports Multiple Output Configurations
– 2 × 50 W Into a 4-Ω BTL Load at 21 V
(TPA3116D2)
– 2 × 30 W Into a 8-Ω BTL Load at 24 V
(TPA3118D2)
– 2 × 15 W Into a 8-Ω BTL Load at 15 V
(TPA3130D2)
I don't have a 24 v power supply and the amp i want to buy is the 2x100 watt amp not the 2x50 watt in 4 ohm amp
I also wrote: i do want 2x100 watt in 4 ohm or close to that since most class d amps has a max power rated at 10% thd
You are showing this amplifier:
https://www.amazon.com/Nobsound-Bluetooth-Amplifier-Audio-Receiver/dp/B07NY19148
They claim:
Real specs are those I posted above, straight from the Manufacturer´s Datsheet.
Read my post again, that is truth, anything else is Fantasy/Lie.
Options are 2 x 50 into 4 @21V or 2 x 30 into 8 @24V
Issued power supply is 19V (typical laptop brick) so probable 2 x 20-25W into 8 ohm.
They claim:
That is a LIE. 😡large output power: with RCA and Bluetooth inputs, adopting 2PCS TPA3116 chip, max output power can reach 200W,
Well, YOU mentioned:I don't have a 24 v power supply
😕i know smsl make a 24 volt 6.75 a and nobousound a 24 6a power adapter,supply, is that enough ?
100W is a lie.the amp i want to buy is the 2x100 watt amp not the 2x50 watt in 8 ohm
Ok, but then you will need a more powerful amplifier, not a TPA3116 based one.I also wrote: i do want 2x100 watt in 4 ohm or close to that
The amp has dual TPA3116 chips and i rembered it's often in 2 ohm compared to the normal 2x50 watt in 4 ohm TPA3116 based amp where it delivers more power
I do have 4 ohm speaker so i could get okay power compared to only having 8 ohm speakers
Close to max power is more like getting close to what max power it can play, but the limit is 7.5a and 26 volt, just under 200 watt for the chip, here is what they rated specs are for the amp
Nobosund say Max. output power: 100W+100W (above 24V@8A / 4Ω) even when thye limite is 26 volt and 7.5a
I think i'm suffering deja vu! We went around a similar conversation a year or so ago, and you were 'advised' to look at other more recent chips than the TPA3116, such as the TPA32**, or the Infineon Merus.
Additionally, your threads nearly always end up with you talking about pwer supplies and, ultimately, ignoring advice and suggestions.
Things have moved on since a year ago, so once agion, look at amps with some other, more recent chips...
your welcome to recommed me something else
I just like the design of the new 2021 nobsound NS-15g and that you can disable the tone controls
here in #29 you can se someones impression of tpa 3251 and 3255 amps
The 2x325 watt amp is as fare as i know not available from a european store like ebay og amazon.de, i do want bluetooth, i think the current AIYIMA TPA3255 300Wx2 is nr 3 Violent pop noise occurs when the power is turned ON/OFF
Which TPA3255 amp do you recommend? | Page 2 | Audio Science Review (ASR) Forum
No bluetooth and have heard the Aiyima A07 should sound better, the price of the amp is accepted, an input selector with bt in stock i havn't found and how big is the sonic difference between the Aiyima A04 and A07 ?
AIYIMA A04 TPA3251 175W*2 Digital HiFi 2.0 High Performance Audio Amplifier Mini Professional Desktop Home Amplificator Audio NE5532 TDA7498E / TPA3116 with 32V5A Power : Amazon.de: Electronics & Photo
The problem is i can't buy one with violent pop noise occurs when the power is turned ON/OFF
The AIYIMA A07 TPA3255 2 Channel Stereo Audio Amplifier 300W*2 cost 60 eueos + shipping but i could have violent pop noise occurs when the power is turned ON/OFF and i wouln't have bt
Does anybody know of a similar amp like th aiyima 07 but with bt and an good high power supply with high a above 6a or more than 24volt
Aiyima A05, with TPA3221 chip, up to 32v:
AIYIMA – amplificateur de son A05 Bluetooth TPA3221, 100W QCC3034 APTX, Mini HiFi stereo classe D, puissance, triple basse pour haut parleur | AliExpress
Sabaj A10a:
SABAJ – amplificateur de puissance numerique A10a MA12070, reglage des basses, caisson de basses, Audio haute resolution RCA avec telecommande | AliExpress
BRZHIFI Bluetooth 5.0 QCC5125 MA12070:
BRZHIFI Bluetooth 5.0 QCC5125 MA12070 Amplificateur 2*80W 2.0 Puissance HD Audio APTX APTX HD HiFi Mini Ampli BRICOLAGE Stereo Home Cinema | AliExpress
I wnt to avoid buyoing from outside of europe do to delivery time and extra expenses , more money like taxes and handling fee from ouit side of europe and uk
I think i have come closer to what i wanna buy, i just don't like the size of the amp so much
AIYIMA A08 315W*2 Bluetooth 5.0 TPA3255 Amplifier Digital Power Amplifier Home Audio Speaker Amplifier PCM5102 Decoding APTX-HD TPA3255 + QCC3034 + PCM5102 with PC USB Power Supply: Amazon.de: Electronics & Photo
input selector
4-Way Analogue RCA Stereo Audio Switch Splitter Manual Switcher Box Preamp: Amazon.de: Electronics & Photo
Or this one
Source selector RCA 4 to 1 / reversible - Audiophonics
input selector
Or this one
You have set IMPOSSIBLE goals.
Answer A:
You have been insisting with that 55 dollar amp for over a year now and have bought NOTHING yet.
Just buy it, period, you can´t afford anything else.
Answer B:
buy it, together with the 24V supply .
Load it with 4 ohm speakers.
Enjoy it tripping off when you play it loud.
Pick ONE: A or B
Answer C: buy it as-is, use it with the included 19V supply, stop dreaming 2 x 100W and most important: ENJOY it.
It is a GOOD amp just as-is.
Stop reading fake Amazon and Alibaba reviews, clearly written by manufacturer shills.
Stop obsessively comparing datasheets and graphs I am not too sure you understand, just LISTEN TO THE MUSIC.
Answer A:
Answer B:
Pick ONE: A or B
- Power Supplies
- Higest power supply for a dua TPA3116D2 amp
