hi lampie519.... thanks but im not sure if that is the neccesary connection for a simple stereo. Are you sure about that schematic?. thanks very much
thanks lampie519. Yes that is why i dont think is neccesary to connect them between each other. i believe they go separated. what do you think?
thanks for that link, i dont understand it. I sent a picture with a connection and the sound goes through but i dont know if this is the right way, or even if is possible to connect it in a diferent way.
AP - EP is the input (Primary). Connect the MP's....
AS - ES are the outputs (Secondary)
In the drawing it looks confusing but when looking a second time it seems more logical. There is a reason for the way they are connected.
Anyway I would take a good look how to separately connect Audio GND and ground connection to chassis (so PE).
- Analog Line Level
- Help to connect MALOTKI transfomers.
