Purifi PTT6.5 3D Models
I modeled the PTT6.5 to better visualize some baffle designs.
It's mostly patched together because the organic suspension was a serious pain to do.
The mount plate, hole spacing, and most importantly the curve profile of the basket were carefully measured with a height gauge, so if you're experimenting with baffle integration, this is for you-
  • PTT6.5-IGS.zip
    PTT6.5-IGS.zip
