KICKER CXA1800. 1 46CXA18001 part identification
I just received a about 10 of these amplifier all look new externally. This one reads a dead short across the power supply, pulled board and replaced the D1 but noticed that Q12 is blown as well.
Yes the short is removed. Bill what is the imprint or can this be found on the scap boards I have a cxa 300-600 or a d 1000. 1d?
I don't see a micro controller on either of the smaller cxa boards. But one is present on the dx1000.1. I'll place an order if not.
Change both out. Tested good in curcuit, but changed them anyway. Amplifier now draws current about the normal amount for start up around 9 amps and holds there instead of dropping, so I shut the supply off.
Because Q12-A03404 burned up I would look at IC17,ZD6-TL431,L4-(I don't have a value, but will look it up). Check the temperature in this circuit, something may be getting hot.
This is an unusual problem, I don't believe I've run across it.
