vFET / SIT data sheets
I know several V-FET / SIT data sheets have been posted over the years across many different threads, but I thought it'd be nice to have them all in one place.
Here's one fresh off the scanner - more to come when I have time to spare. Meanwhile, feel free to attach or link to whatever you have.
(Note to Mods: I hope posting these doesn't violate rule #9 - please delete the thread if you think otherwise. Thanks!)
Edit: I realize my file naming convention is not immediately obvious ==> the attached PDF contains 2SJ18, 2SK60, 2SK63 and 2SK79.
You are welcome! 😉
And here's the Yamaha stuff - "borrowed" 😱 from audiodiyers.hu (I am still trying to get my hands on that particular data book).
@ Petoluk
Thanks for datasheets :cheerful: Good idea
+ received this one from Sibatech Co. distributor of Maxonic and FAL products.
Tokin 2SK180, 2SK182, 2SK182ES, THF-51S
Reactions: jotom750
Tokin SIT 1KWatts: 2SK182, 2SK183, 2SK183H, 2SK183V
Source: extracted from inverters tech documentation
Tokin datasheet :superman: credit to Mr. Michael Rothacher
+Classic
Bad Boyz Pentodes SIT
Bipolar SIT version with pentode transfer curves
Probably TM series are triodes but TBM are pentodes.
Transistors pair or quad in one case
YAMAHA SIT/VFET Family
Quoted from a dissertation by the designer of YAMAHA.
Mochida, Yasunori. Research on Static Induction Transistors for audio amplifiers, 1982?
This data cost more than SIT device 😀
and more
WOW, that's awesome! Thank you very much!! 🙂
The SONY book was pretty pricey too - it broke my heart a little when I had to rip it apart to be able to do proper scans (the book is VERY thick, with text / graphics very close to the inner edge, so trying to scan it as is was futile - that inner part [~1/3] of each page was completely deformed / blurred).
