BAT VK-40 6-pack capacitor upgrade
BAT has their own name on the capacitors, since most cap companies will add your label to a stock part
for a small charge. You can easily make up something similar with parts of your choice, though.
The response is -3dB at 100Hz into 600R, so they amount to a total of around 3uF.
