Power supply cooked up, and the component values are not visible anymore.
Does someone has the values or a photo from the burned components?
R234
R231? (Marking burned)
R250
R251? (Marking burned)
R234
R250
hello can you help me on this amplifier my text and translated via Google the original text is in French the problem is that I replaced the resistors burn the fets and when I plug in the amplifier the red LED lights up for a moment and then the blue flashes with the red do you have any idea about the problem thank you very much
Please don't post in a repair thread that was started by someone else unless you are trying to help them.
Start a new thread if you need help with a repair of your own.
MerciS'il vous plaît, ne postez pas dans un fil de réparation qui a été lancé par quelqu'un d'autre à moins que vous n'essayiez de l'aider.
Commencez un nouveau fil si vous avez besoin d'aide pour une réparation de votre part.
- General Interest
- Car Audio
- Audison SR1DK resistor value
