Another hybrid design, this time SE
I've seen this article:
r-tec2102_(07)superT-ULD-amp_KurodaT.pdf - Google Drive
taken from this site:
記事録 2021-2022
and I decided to simulate the circuit at page 109, because I already have a SE pcb that can be modded to adopt that design.
These are the results of the hybrid SE amp with EL84 at 4.3 Wrms:
Code:
Harmonic	Frequency	 Fourier 	Normalized	 Phase  	Normalized
 Number 	  [Hz]   	Component	 Component	[degree]	Phase [deg]
    1   	1.000e+03	8.272e+00	1.000e+00	   -0.52°	    0.00°
    2   	2.000e+03	1.318e-01	1.593e-02	  -90.87°	  -90.35°
    3   	3.000e+03	3.921e-02	4.739e-03	    0.15°	    0.67°
    4   	4.000e+03	1.057e-02	1.278e-03	   89.51°	   90.03°
    5   	5.000e+03	4.913e-03	5.939e-04	 -175.41°	 -174.89°
    6   	6.000e+03	2.385e-03	2.884e-04	  -95.19°	  -94.67°
    7   	7.000e+03	2.314e-03	2.797e-04	    7.19°	    7.71°
    8   	8.000e+03	3.984e-04	4.816e-05	  -95.69°	  -95.17°
    9   	9.000e+03	5.549e-04	6.707e-05	  178.40°	  178.92°
Total Harmonic Distortion: 1.668950%(1.669417%)
  • 6bq5_5w_amp.asc
    6bq5_5w_amp.asc
This is a version with EL34 at 10.5 Wrms:
Code:
    1   	1.000e+03	1.294e+01	1.000e+00	   -0.40°	    0.00°
    2   	2.000e+03	3.188e-01	2.463e-02	  -90.80°	  -90.40°
    3   	3.000e+03	1.355e-01	1.047e-02	   -0.62°	   -0.21°
    4   	4.000e+03	4.104e-02	3.171e-03	   88.63°	   89.03°
    5   	5.000e+03	3.165e-02	2.446e-03	 -179.68°	 -179.28°
    6   	6.000e+03	1.520e-02	1.175e-03	  -94.37°	  -93.97°
    7   	7.000e+03	1.282e-02	9.909e-04	    0.54°	    0.94°
    8   	8.000e+03	4.709e-03	3.639e-04	   83.68°	   84.09°
    9   	9.000e+03	3.512e-03	2.713e-04	  164.98°	  165.39°
Total Harmonic Distortion: 2.711032%(2.711414%)
Roberto,
Thanks for your post.
I’m watching your simulations because you do interesting stuff, but also to help me learn LTspice, and I have a question regarding the primary inductance of the output transformer. The value in the schematic seems high to me for a SE transformer, or is the value in the simulation some multiple of a real life transformer?
Neither I to give more articulated answers by now! 🙂
There are probably alot of possible improvements on my adaptation for the EL34, but it is at least promising! It is a nice way to give local feedback to the power tube, improve distortion and damping, plus avoid coupling and (some) supply caps at the same time: one single supply node is enough for the whole channel.
This can make the whole amp smaller, cheaper and easier to build.
Hi, here it is a KT88 version with the following results at 18.6 Wrms:
Code:
    1   	1.000e+03	1.722e+01	1.000e+00	   -0.24°	    0.00°
    2   	2.000e+03	3.598e-01	2.089e-02	  -91.15°	  -90.91°
    3   	3.000e+03	2.633e-01	1.529e-02	    0.04°	    0.29°
    4   	4.000e+03	3.509e-02	2.037e-03	   83.51°	   83.75°
    5   	5.000e+03	6.225e-02	3.614e-03	 -179.11°	 -178.86°
    6   	6.000e+03	1.342e-02	7.792e-04	  -98.18°	  -97.93°
    7   	7.000e+03	2.327e-02	1.351e-03	    0.08°	    0.32°
    8   	8.000e+03	2.522e-03	1.465e-04	   72.67°	   72.91°
    9   	9.000e+03	7.891e-03	4.582e-04	  179.25°	  179.49°
Total Harmonic Distortion: 2.626568%(2.626863%)
  • Hybrid SE KT88.asc
    Hybrid SE KT88.asc
@Francois: I've done simulations with original design and I've bought some questionable ones, then I'll try with equivalents.
@indra1: thanks for the suggestion!
@euro21: I've used the "alt+click" command on the KT88 to show its dissipated power, then the "ctrl+click" command on the plot of the dissipated power to show its average value, and it tells me around 36 W. How can it be wrong?
Francois G,
You are correct. I was unkind.
I used to want to use JFETs in Vacuum Tube amplifiers.
But I found that they often have a very large spread of specifications.
Example, the 2SK30A
IDSS ranges from 0.3mA to 6.5 mA (Drain current, with the gate at 0V with respect to the Source, and Drain to Source voltage 10V).
Gate cutoff (for 100uA ID) ranges from -0.4V to -5.0V (with the Drain to Source voltage 10V).
It is very hard to design with such a large spread of parameters.
The 2SK30A is expected to work at 10V Drain to Source.
I think that any vacuum tubes that have that large of a spread, need to be thrown into the garbage.
Imagine a 12AX7 that has 100uA plate current when the grid ranges anywhere from -0.4V to -5.0V.
Imagine a 12AX7 that has 0.3mA to 6.5mA with the grid at 0 Volts.
True, the 12AX7 is not going to work predictably at only 10V on the plate.
But for more realistic fixed plate voltages, say 90V, 150V, or 250V, it will not have nearly as wide a spread of parameters as are listed above.
Interesting discussion... But is it worth having a FET input and tube output - just to get rid of a coupling cap between the 12AX7 front end and the output tube? How does this compare to a SRPP 12AX7 R-C coupled to the output tube?
Hybrids are normally done with tube amplification and MOSFET or FET outputs. P & N type so we don't need output cap...
Many things can be built of course - each with it's own sound. So by all means, crack on with this one. It is a hobby after all. Thanks for sharing.
D.
Hi vilfort,
I already have an hybrid PP amp (you can see reference here: improvements on 12AX7 12AT7 EL34 schematic? ) and also another user of this forum developed his own version of that amp ( 100W + 100W amp to share ) and I have to say I'm happy with it as it is now. Everything is improvable, most probably this won't be the best sounding amp ever built, but as a newbie I consider the design interesting.
I'll try to design a PP version of it, doubling the circuit and adding a CCS on the sources of the jfets.
