Help building high pass crossover
Hello,
My first post for home audio. I currently have dual 4-10s made by Tekton. I'd like to high pass these speakers to work from 50hz into a 4ohm load maximum rms by amp 300watts.
The Tekton Design 4-10s have a low pass crossover up to 200hz. So, I'm thinking I could crack open the subs and add a passive high pass from 50hz. That way the subs will be bandpassed from 50hz to 200hz. I'm thinking a 12-24db crossover slope would suffice.
I'm looking for hows to build my own. Parts and diagram if you'd be so gracious to help out?
Overview: I have Tekton Design Ulfberht mains. And I have dual 4-10s which I'd like to bandpass. I'm looking to add dual subs from 50hz and below and is why I am here inquiring on how to passively dual bandwidth the 4-10s.
Much thanks in advance,
William
It's difficult to design passive filters with high order slopes. Over 6dB would be best as active.
Active Filters
