VTL5C1 alternatives for channel switching
Joined 2011
Hi everyone,
I was wondering what would be a best alternatives to VTL5C1 opto switches used in Soldano amps?
Would this available part NSL-32SR3 be a drop in replacement?
Also browsing the internet I found some drawings using 8-legged couplers there, but cant get any information on which exactly? Here is a fragment of the schematics attached.
Of course people are switching to relays, but heard you would need to do some muting in order to eliminate clicks.
Thanks!
Yes, should work.
Or make your own: a Red Led, a 5mm (or thereabouts) CDS photocell, a bit of heat shring tubing.
I make my own since forever because VTL*** are not available in Argentina or ridiculously expensive.
I have been using these surplus devices in my vacuum tube amp, compressor, and music synthesizer circuits for a few years.
They are probably reject parts that don't meet the full specs since there is a pretty wide variation from part to part. I have not tried them in a channel switching application like Soldano does, but these are cheap, and until Sunday they are real cheap, like 25 cents each.
Last time they had them on sale I got a box full and I just try a few until I get some that work in my design.
G15396D - FLASH SALE! (Pkg 12) Audio Opto Coupler
