Speaker mounting what to use between speaker driver and box.
Hello i was taking apart a tandberg tl 1500 anyway there was something on the back of the drivers that worked as a glue and a cushion between the speaker driver and box. Anyway since it was deterioating i removed it but what soft non vibrant thing can i use as a replacement?
I stopped using gasket material between driver frames and cabinet. If the driver has a gasket attached, I leave it. It does no harm, but it serves no real purpose.
If I had an irregular baffle surface to mount the driver, I might use a gasket. but if the baffle is flat and smooth, I just screw it down tight.
>even some expensive loudspeaker do not use any gasket between driver and cab...
I once met a fellow who suggested removing such gaskets for better sound. He called it "free and easy upgrade for almost any speaker system".
Personally, I dont put a lot of stock in the idea. Who knows what others can / cant hear.
Blacl foam+circle cutting compass
Hi.
I built a SEAS Loki kit and the driver recesses in the kit enclosures are deeper than the woofer flanges. I got some 2 mm thich black foam,
12" x 18" Foam Sheet by Creatology™ | Michaels
and an Olfa cutting compass,
OLFA(R) Rotary Circle Cutter
I then punched holes for screws with a regular hole punch. Works very well, is removable and lasts forever (so to speak). I have used the same material in the past in other builds. However, for cast aluminum basket woofers on a smooth mounting surface, having no gasket at all has worked well too in some speakers I made, as mentionned in another post above. Cheers!
--Christian
