My new project: GaN amp and LLC+SinchroRec PSU
Amp have full differential structure
Amp- 400 4 ohm, 200 8 ohm nominal power, 600 and 300 maximum power.
Amp have overload, overtemperature protections.
With my PSU have DC protection.
PSU LLC and sincrorectifier.
Hallo Dr!
Full diff should mean a very quite ground - do you for-see this?
It can be important as what is feeding the signal input to the amp will most probable share this ground and if that is "rocking", it will rock too...
What is your goal with this amp over the last ones?
Thank you for keeping the forum alive with good content, the last year all we seeing is copy paste evaluation pcb chip designs.
