Hello,
This is Sreenath, And been a member here for a long time. Hope you all are fine.
Actually I am facing a problem where I bought this TPA3116 Bluetooth Amp with CSR8635 on it, & after I had it installed for my speakers i thought why not I adjust the EQ/DSP to sound perfect.
But, now for some reason I tried to run the PS Tool & Rom Configurator for it and it worked without a problem. But for Some reason the Parameter Manager is not Working.
I tried the CSR8635 ROM Series A03 UFE(CVC) on Win 10 & 7 32bit and it showed this error - The algorithm connected to USB SPI (1003432) identifies itself as E00C @ 44100 Hz, for which there is no available support.
If anyone reads this post please help me get a appropriate Parameter Manager to Control the DSP of CSR8635.
I am curious, how did you manage to access the DSP of the 86325. Is there some USB socket at the amplifier board of sorts that allows you to connect to the PC to program it?
Oon
Oon
This looks like a clue: Where can I get CSR DSP Equalizer configurator? * Issue #17 * lorf/csr-spi-ftdi * GitHub
"The main trick for the equaliser program is to run it under 32b windows 7 (as un-updated as possible), and to have music playing, otherwise the Kalimba DSP is sleeping (more like dead) and can't be found by the software"
Hope it helps - I'd like to have a go at this myself
Oon
Actually I bought a CSR SPI to USB Converter and hooked up the connection on the pads below the bluetooth module of the amplifier.
Thanks for the suggestion, but I already did that by running it under Virtual Box with Windows 7 32bit, but unfortunately that didn't work too.
I think there might me another version of the program that might work for csr8635.
Thank You.
I used this class D amplifier board.
2 x 50W Bluetooth Stereo Audio Amplifier Board - TSA3118B(TWS/Apt-X)
The programmer in this one works but it is a different chip, not sure if it will work on yours. It is also based on a usb to spi converter. so you might give it a shot.
Oon
Oon
