Rockford Fosgate R400-4D
Anyone know what diodes these are or have a part number ?
D211 was shorted
It connects between the drain of the output and the driver ic .
Does anyone know what one is likely being used out of the 2 I posted?
How do I tell what regulator goes here ?
When I powered it up it blew the face off it and not sure where the gave of it went ?
It’s either a LM337 or a LM 317
Just wondering how do I tell which one it is
IC705 is a LM337
Amp powers up and produces rail and regulated voltages I just can’t it to produce any audio .
Not sure if these are the muting transistors but for there to be no audio on all 4 channels and ever single muting transistor bad is probably unlikely
Ok got this amp back with a new problem .
It’s stuck in protection mode .
Here is what I get on the 494
Pin 1:4.21
Pin 2:4.97
Pin 3:0.10
Pin 4:0.07
Pin 5:1.59
Pin 6:3.36
Pin 7:0.00
Pin 8:12.67
Pin 9:5.13
Pin 10:5.13
Pin 11:12.67
Pin 12:12.67
Pin 13:4.97
Pin 14:4.97
Pin 15:7.97
Pin 16:0.00
