Im only getting rail voltage on half of the outputs .
Q2011,2014,2008,2006 have no tail voltage on any of the legs .
Any ideas ?
Any ideas ?
If 'what' is defective?
Positive 31v?
Did you check for continuity from the negative rectifier to the source legs?
Do you have another junker of this basic type to confirm that you should have a 0 ohm connection between the negative rectifier and the source legs?
Positive 31v?
Well that explains why the amp has no negative rail voltage .
The outputs are blown which my meter must be dying since they tested good the first time around .
To clarify, These amps have only one rail. There is no fixed positive or negative rail voltage that you can measure. You have to measure across the rectifiers to know if they have rail voltage.
Replaced the defective outputs and I still only get rail voltage on 4 out of the 8 outputs .
Q2011,20142006,2008 have no rail voltage .
I measured across the rectifiers and have 63 volts of rail
Then, I'd recommend pulling the rectifiers (or at least the center terminals) and check the drive signals. Post a photo of the BD driver board.
Do you have the correct output voltages on the SMD regulators near the driver board?
Are the solder connections good or do they appear to be damaged from heat?
I have + - 14 volts going into 2 and +- 19 volts going into the other 2
Coming out I have -15 coming out of 2 and -27 on 1 and 20 volts on the other
- General Interest
- Car Audio
- Rockford Fosgate P1000-1BD
