Does anyone have a picture of the area around the 494 ?
Someone has been inside this amp before .
The reason I ask is becomes the leds do not work for the high power nor the high current .
I’m not getting voltage to either one
The 1000s uses an SG3524. Are you sure that the x version uses a 494?
I have photos and the diagram for the S but nothing for a 1000sx.
Sorry your correct it uses the 3524 . Have my amps confused since I’m working on 2 at the same time .
But yes I need a pic of the power supply area
The leds for this amp should have 12 volts on the positive terminal correct ?
I’m
Only getting 0.68 volts on the positive Terminal for the leds
I’m
I don't understand the question. The op-amp U9 is powered by the ±15v supply. In one mode, t's output will be about +15v. In the other mode, the output voltage will be -15v.
What voltage do you have on pin 7 of that op-amp?
Switched up amp and same issue .
All the voltages are correct and have the same voltages on the new opamp
It's a comparator with no feedback so the output should swing to the rails. I can't explain why it's not.
Back to this amp again .
Even with U9 removes I get the same voltages as before
I’m starting with the SG3524N do these voltages appear correct ?
Pin 1:2.44
Pin 2:2.45
Pin 3:0.25
Pin 4:0.00
Pin 5.0.00
Pin 6:3.30
Pin 7:2.20
Pin 8:0.00
Pin. 9:1.44
Pin 10:0.00
Pin 11:1.28
Pin 12:13.79
Pin 13:13.79
Pin 14:1.36
Pin 15.13.15
Pin 16:4.91
Voltage on gate legs of fets is 0.95
Pin 1:2.44
Pin 2:2.45
Pin 3:0.25
Pin 4:0.00
Pin 5.0.00
Pin 6:3.30
Pin 7:2.20
Pin 8:0.00
Pin. 9:1.44
Pin 10:0.00
Pin 11:1.28
Pin 12:13.79
Pin 13:13.79
Pin 14:1.36
Pin 15.13.15
Pin 16:4.91
U9 is a TL072 and it’s not working correctly trying to figure out why it has no voltage on pin 7 . The amp is not switching from high current to high power that part of the amp is dead and does nothing at all .
The voltage on pin 7 is determined by the voltage on pins 5 and 6. It's a simple comparator circuit. If the IC is not defective, there is no reason that I could see that the output wasn't going high/low.
The 3524 can't do anything to influence the output on pin 7.
Maybe someone else will be able to help.
- General Interest
- Car Audio
- Soundstream 1000sx
