Hifonics BX1000D
Hello, I am repairing this Hifonics bx1000D it came with problems in the output. Does anyone know if the 10uf 250v capacitors that go on C19C C20C are polarized or not?
is that the problem I have is that the red LED turns on, not the protection LED the other one and the relay is not activated there is no audio the mosfet output is fine as well as those of psu leeo 46v 15+ 15- check the 2ohm resistances and pk diodes are ok does the same with or without the hip4080ipz
