Memphis PR1-1000 Zener ZD1 value?
Here is the data sheet; 110volts 400mW
Is the problem that they're not printed well or that it's too small to see?
If you have a supply that's capable of producing more voltage than the Zener, you can insert a 1k resistor (starting point) in series with the Zener and increase the voltage across the resistor/Zener until you see where the voltage across the Zener stops increasing.
Too small to see.
Should I be able to read the DC voltage of the zener regulator on the non-grounded side of the zener? There is +12 into the 33 ohm resistor on one regulator and -12 on the other 33 ohm. On the regulated side there is less than .5V. These regs service the IC's on the output driver board. Could they be bad and are loading the regulator.
If you're in the US, a 'DrMon otoscope' (walmart) is a great lighted magnifying glass.
You measure directly across the legs of the zener diode. Do not power up the amp with any Zener diode out of the circuit.
It's possible that something on the driver board or on the main board (shorted cap) could be pulling the voltage down. Photos or at least circuit board designations would be very helpful.
The driver board was in backwards.
I could not figure out why the +9.1 from the + zener regulator was going to the negative V pin on the IC's.
I pulled the driver board and surprise the board pinout was underneath where you couldn't see it.
After pulling board the zener supplies 9.1V +/- are stable. You were correct on suggesting the 1N4739A as it turns out.
Now if I set the board back in correctly the IC's are stable on the -9.1V pin but the V+ pin is probing -5.7V. And the output at the +9.1V zener is drawn down to +8V. Not sure if it is a great connection as I have not soldered the header pins on the driver board.
Possible that the reverse polarity on the IC's damaged them? All other components on the driver board are checking ok.
That is where my troubleshooting started in that I was trying to figure out why I had wrong voltages on the driver board IC's. I traced it back to the shorted zener. Now that the zener's have been replace and the board is in properly (although not soldered) I am probing the V+ and V- pins on the driver board IC's:
V+ -5.7
V- -9.1
Then when I check the voltage at the zener for the +9.1V it is drawn down to +8V.
There does not seem to be any components in the path between the zeners and the V+ and V- pins of the driver board IC's.
Output fets are not on board yet.
No significant hot components on driver board. Soldered the driver board back in and getting consistent readings on the output fet pads as follows
Hi side:
G 50.37v
D 0v
S 61v
Lo side:
G -60.88v
D 0v
S -61v
No drive wave.
The hi side has the 11v dc offset between gate and source at idle.
On the driver board there is this arrangement of zeners. It seems to trace out as I have drawn. Do these regulate the gate voltage? It seems that the lo side is within a volt at idle and that identical set of zeners seem to be taking the rail and dropping it down?
