First attempt at a crossover
The full range mid driver Fostex FF125WK has a nasty bump at 7k, advice sought as to what values and what elements to use for smoothing ?
any experienced advice greatly valued and appreciated
my MacBook can’t find any free software that’s works
Martin
Martin
Have a look here for an example of what a fullrange needs (baffle step compensation and breakup): Zaph|Audio
I suggest you pick a proper simulation software, the online calculators can be useful only as a starting point in this situation. XSim is good, you need to trace the FR and impedance of the driver. You need a windows machine, I don't know if a VM under the Mac would suffice.
Ralf
Ralf
You may not need to suppress that spike anyway but if you still feel like doing it, ok. A simulation is useful, especially when fed with your own measurements.
