Pair Magnequest EXO 045 single ended parallel feed output transformers, 5k, 8 ohms
Asking $300
Ship Canada and USA
NOTE:
(google French English translation)
My friend who sold them to me thought they were cobalt so I made a first ad saying cobalt. have told me it was not cobalt. I canceled the announcement and made a second ad and
I assumed it was nickel because below it is marked N, but a guy said that means no DC.
So I don't know what metal they are.
Asking $300
Ship Canada and USA
NOTE:
Will it worked in this application? I'm in Laval... It says 'No DC' so I'm guessing not since the 5K primary is in serie with the HV supply in this application...
SB
SB
Are you sure these are nickel? AFAIK Mike always labels them as such if the lams are non-standard (i.e. not M6). I don’t see “NI” below “EXO045”.
Hello. I add this note to my ad
My friend who sold them to me thought they were cobalt so I made a first announcement saying cobalt. have told me it was not cobalt. I canceled the announcement and made a second announcement and
I assumed it was nickel because below it is marked N but a guy said that means no DC.
I redo My Ad
Pair Magnequest EXO 045 single ended parallel feed output transformers, M6 lamination, 5k, 8 ohms
Asking $200
Ship Canada $12 and USA $15
Asking $200
SB
On your circuit the parafeed output transformer primary would be connected through a capacitor either between plate and "white/red" connection or from "red" to ground.
The B+ series plate load component can be inductor, ccs, or even resistor and with the EXO-045 (in series with the parafeed capacitor). The plate choke is the usual way and handy as it can swing above B+, but within power limitations CCS can work and a friend tells me that you get the best sound with resistor. : )
