Joined 2009
very nice speaker building kills!
what did you do with the screen grid in you 6E5P ?
Screen grid is connected to anode with 180Ohm resistor.
fourth try (class A2)
Power: around 6W
Sound: very, very good, I realy like it
THX to ARTOSALO for idea
If I were you I would replace RC connected to both cathodes with 12 to 15 red LEDs ie. 3 LEDs in series and such chains then connected in parallel. Sound should be much better.
Joined 2009
I found the difference between R+C and LED to be very subtle and would have been happy with either - the LED being slightly cleaner sounding, but only slightly. When using 6E5P as power tube there's plenty of current to keep the LED at a point of low impedance so it should be fine to use a single one ?
In the end I used a single LED in my SPUD amp because it was physically much smaller and I like the golden glow (amber LED) inside the chasis !
Unfortunately, I didn't like the 6E5P, it was a bit too clean, slightly harsh (I used grid stopper, careful lead dress and no evidence of oscillations on the 'scope) so I ended up with 6P15P instead.
Maybe I'll try the 6E5P again.
p.s. I agree with Vladimirk, these tubes have high gm, so physical construction requires extremely tight tolerance but in the end they usually have quite a variation in parameters. If you parallel tubes you probably have two different tubes in reality. Maybe helps to have separate cathode resistors ?
no preamp, can I?
Can I just use 50Kohm potentiometer and feed signal from DAC to this simple amp?
Power: around 6W
Yes. You can.Can I just use 50Kohm potentiometer and feed signal from DAC to this simple amp?
I use this one:
Ogonowski.eu - profesjonalne transformatry do wzmacniaczy lampowych
It is very good.
It is very good.
- Tubes / Valves
- My 6E5P amps (SPUD)
