True. However spectral views are typically power spectral density plots. That's why scalloping is down by 3dB for frequencies exactly between bins. Otherwise it would be 6dB, wouldn't it?FM and AM of a pure tone will have identical levels of sidebands. But they sound different, how is that possible? That's because the sidebands have opposite phases for the two modulations and this would only be seen if one looked at the phase, which a spectral plot does not usually show - it's not shown because it lacks significant importance (there are some issues to be sure, but it's mostly the group delay rather than the actual phase,) but this phase information is there in the data.
Yeah, and how much time and money does it cost to prove every little thing that is audible? If you want to pay for the cost of a study, I can arrange to repeat the experiment.And this has been shown to be statistically audible in a blind test were? If not then I'm not interested.
Anyway, of course current noise is an intermodulation with an audio signal, since it is a multiplicative process. Its like you have a noise source and a VGA. You feed noise into the VGA, then you use an audio signal to drive the VGA gain, then add the VGA output with the audio signal. How is that not producing a modulated noise effect? The noise level goes up and down with the audio. If the noise is going up and down then there must be sidebands (which is well known by people who do the electronics) because the noise amplitude is not composed of steady-state sine waves any more. There have to be few frequencies created that correspond with the gain modulation.
Moreover, the people who manufacture resistors (such as Susumu) and make special resistors for audio say that the audio resistors are optimized for low noise. Even those guys know current noise can be audible.
Which is a clear reason why one would use a steady state signal because then this won't happen.Short time FFTs are used to measure nonlinear systems because they have less averaging effects of time-domain changes.
DitoIts simply a consequence of the well known fact that more resolution in the frequency domain corresponds with less resolution in the time domain. Thus, signals which are changing in time show up as more averaged effects in high resolution FFTs.
I have used cross correlation methods extensively myself (classical signal processing.) I don't use them anymore because other methods are far superior.Another way of explaining the effect is that DFTs can be calculated by correlation.
That's one of the old ways of calculating them by hand.
Then don't make the mistake that you described.A non-PSS signal, one that is changing frequency, amplitude, being gated on and off, etc., during the time an time-series dataset is being acquired for FFT analysis may have low correlation on average with a particular FFT bin.
An easy to imagine example would be a frequency sweep across the audio band while FFT data is being acquired. If equal power of the sine sweep is correlated with each bin frequency, then the sine sweep will look like a noise floor. Obviously that's not what it really is.
It has been shown many many times that measurements done correctly always show the exact same things regardless of how they are performed - sweep sines, noise, whatever, all yield identical results.
Sorry, but sigma delta dacs can do just that. The effects are called chirps.Then don't make the mistake that you described.
Also, what about when RF gets into an amplifier? According to Bill Whitlock it often happens through the AC power line. According to him the sound effect can be "veiled" or "grainy." Have you ever measured the audibility of veiled or grainy?
I mean, you are saying "don't do that," for real problems that plague people's systems.
But that doesn't matter, the phase is still there in the transfer function regardless of how it is displayed.True. However spectral views are typically power spectral density plots.
This system is nonlinear. Multiplicative processes in the time domain are not linear. Time domain signals in a linear system can only add.Anyway, of course current noise is an intermodulation with an audio signal, since it is a multiplicative process. Its like you have a noise source and a VGA. You feed noise into the VGA, then you use an audio signal to drive the VGA gain, then add the VGA output with the audio signal. How is that not producing a modulated noise effect?
Then they are correlated and that's not common noise. We usually think of noise as being uncorrelated to the signal. Perhaps there is some strange process in electronics that allows this (it is nonlinear,) but I don't think that it is common.The noise level goes up and down with the audio.
I'm not going to justify crappy designs.Sorry, but sigma delta dacs can do just that. The effects are called chirps.
Again, it's not my area, but your claims seem unlikely to me. RF shielding is not a new subject - fix it.Also, what about when RF gets into an amplifier? According to Bill Whitlock it often happens through the AC power line. According to him the sound effect can be "veiled" or "grainy." Have you ever measured the audibility of that?
It does matter exactly because a human is interpreting the visual plot and concluding with absolute certainty that AM and FM can't sound the same because the what they person is looking at doesn't look different.But that doesn't matter, the phase is still there in the transfer function regardless of how it is displayed.
Of course not. But you have to understand you are justifying Ethan's ignorance when it comes to misinterpreting what he is looking at.I'm not going to justify crappy designs.
He designs something with RF getting into it, with correlated noise, can't see any of that crap on his computer display, then makes up really poorly designed tests with all kinds of veiled, grainy, correlated masking noise in them to prove to people they can't hear crap when they are actually hearing real problems in their systems. And those same poor people don't know how to troubleshoot because they are using the same stupid spectral views because that's what everybody does.
@Markw4 Can you provide some measurements of the behavior that is described above? Some plots of results and explanations would hopefully help me understand the nature of the problem much better than I do at present.Anyway, of course current noise is an intermodulation with an audio signal, since it is a multiplicative process. Its like you have a noise source and a VGA. You feed noise into the VGA, then you use an audio signal to drive the VGA gain, then add the VGA output with the audio signal. How is that not producing a modulated noise effect? The noise level goes up and down with the audio. If the noise is going up and down then there must be sidebands (which is well known by people who do the electronics) because the noise amplitude is not composed of steady-state sine waves any more. There have to be few frequencies created that correspond with the gain modulation.
Isn't that just an example that a human is simply looking at the wrong type of plot for the problem at hand? Transfer function analysis is a readily available tool.It does matter exactly because a human is interpreting the visual plot and concluding with absolute certainty that AM and FM can't sound the same because the what they person is looking at doesn't look different.
Sometimes the measurements are incorrectly referred to a phase noise (PN) skirts. Sometimes they have also been presented at ASR that way (as a measure of jitter more sensitive than J-test). However the skirts also contain information about intermodulated (correlated) amplitude noise (AN).@Markw4 Can you provide some measurements of the behavior that is described above? Some plots of results and explanations would hopefully help me understand the nature of the problem much better than I do at present.
Some measurements and an overall thread worth reading is at: https://www.diyaudio.com/community/threads/phase-noise-in-ds-dacs.387862/post-7063038
Regarding the relationship between AN and PN skirts, a diagram may be helpful:
Also, a recent paper on separating AN from PN in dacs is attached.
Please note that the effect of current noise is described in another thread as an edit at the end of main post: https://www.diyaudio.com/community/...-for-measuring-amplifiers.363385/post-8046825
Hopefully the noise skirts discussion will help make clear its not a matter of transfer function either.Isn't that just an example that a human is simply looking at the wrong type of plot for the problem at hand? Transfer function analysis is a readily available tool.
As an aside, as shown in one of the other threads, PN of analog oscillators can be a problem too. I believe the second image in the post at: https://www.diyaudio.com/community/...-for-measuring-amplifiers.363385/post-8046873 ...is of an analog oscillator. One solution to that problem is to use dacs as test signal sources combined with an LP filter to suppress HD in the dac output. PN of test tones produced that way can be superior to analog oscillators.
But isn't RFI a well-known problem? There is plenty of sensitive electronic gear out there that would be significantly and adversely affected by RFI, not just audio gear where so-called "veiling" and "graininess" might surface. So, don't all audio equipment designers ostensibly guard against RFI during the equipment design process?Also, what about when RF gets into an amplifier? According to Bill Whitlock it often happens through the AC power line. According to him the sound effect can be "veiled" or "grainy."
Yes, in principle at leastBut isn't RFI a well-known problem?
By law, at least where I am, there is a requirement that devices not emit EM radiation beyond statutory limits for home use equipment.There is plenty of sensitive electronic gear out there that would be significantly and adversely affected by RFI, not just audio gear where so-called "veiling" and "graininess" might surface. So, don't all audio equipment designers ostensibly guard against RFI during the equipment design process?
There is zero requirement that a device have measurable immunity from such emissions or from other sources of EMI/RFI.
Thinking about it for a moment, what if some devices were designed at added cost for better EMI/RFI noise immunity, how much more would consumers be willing to pay for that feature? Have you ever seen such an advertised feature?
Probably not. But what you may see is that even Topping sells USB isolator devices designed to make a dac sound better than it might otherwise. They aren't selling general EMI/RFI noise immunity, only something that may or may not help with one source of problems.
So, what I see in the actual market in the case I described is not what your question seems to be suggesting. Moreover, IME its not the case in general that there is more money to be made in the consumer market selling more expensive equipment on the basis of it having improved EMI/RFI immunity. Consumers appear to want rock bottom pricing overall. For those that follow the ratings over at that other audio website, its all about SINAD/$ as measured on a very low EMI/RFI emissions AP 555x. The measurement machine doesn't measure EMI/RFI immunity, so for most people its a worthless concept that is completely irrelevant to purchase decisions.
- What's the problem with modern proper loudspeaker cabinets decoupling?
