The original QUAD 33 has a switchable low-pass filter, but no 20 kHz setting, only 5 kHz, 7 kHz, 10 kHz and cancel. I don't know about the new QUAD 33.
A full power pulse with rise time equivalent to a 20 KHz sine wave would likely destroy most conventional tweeters. The worst case for vinyl source is a scratch or dust click causing the cantilever to ring as a fast damped oscillation at around 15 kHz with most MMs that I have measured.
I concur.Another large signal parameter thats not discussed but could be significant for audio is settling time- the time for a system to recover to a small percentage from a transient. This is difficult to measure accurately but could explain some of the differences that distortion measurments don't show. The challenge is a clean transient so you are not measuring the source and high resolution of the transient if you are looking at .01% settling time.
I have found in my experience faster internal circuitry, higher slew rate and shorter settling time seem to translate into better sound. However I could be fooling myself.
If you are into short 0.00X % settling times, try to avoid pole-zero pairs with relatively large time constants. The pole will never be exactly on top of the zero, so you will get a small term in the step response that damps out with a large time constant. Op-amps like the NE5532 and NE5534 are then to be avoided, as are vinyl records, tapes and FM radio.
Whether the treble unit would be damaged depends on how short the pulse was. A well designed 19mm treble unit should take 1000W peaks easily with low distortion if they were only 50 usec long eg 1 cycle of 20kHzA full power pulse with rise time equivalent to a 20 KHz sine wave would likely destroy most conventional tweeters. The worst case for vinyl source is a scratch or dust click causing the cantilever to ring as a fast damped oscillation at around 15 kHz with most MMs that I have measured.
But you are right that clicks & scratches are the most demanding 'high slew' signals with vinyl but also the most likely to clip a well designed RIAA preamp. Whether they should be allowed to do so is unfinished business for me.
If an amp is adequately compensated (and that may involve attention to the front-end BW limiting filter), there should be no overshoot or ringing into a resistive load, no matter how fast the stimulus rise/fall times are. The only fly in the ointment here would be TPC compensation, which does show in-band peaking. But, in this latter case, you can mitigate it by further limiting the input bandwidth. However, TPC shows none of these problems, and neither does MC if the phase margins are adequate.
Actually I've used similar techniques, both analogue & digital, fixed & adaptive in some experimental versions of my Powered Integrated Super Sub technology but this was at LF rather than HF. The commercial implementations were all analogue as this when computing power was $$$ ... especially good ADCs & DACs.As you are in the habit of driving amplifiers into clipping, maybe the phase shift of the filter happened to reduce the peak level, so the clipping was less hard? I know some broadcasting stations used all-pass filters for peak reduction, although I don't know the details - in particular, whether they use fixed or adaptive all-pass filters.
I've conducted/been involved in separate DBLTs to investigate several of the aspects you list. In each case, it was important to conduct the test such that these other aspects didn't obscure the aspect being tested.If "properly conducted" means that side effects like phase shift in the passband, roll-off in the passband, clipping, slewing or anything else that causes intermodulation in the amplifier or loudspeakers have all been excluded as a cause for the heard differences (but your last sentence seems to contradict this), then your test subjects must have been able to hear frequency components above 20 kHz while listening to music (and as the human auditory system is not linear time invariant, this doesn't imply that they could hear sine waves above 20 kHz).
https://aes2.org/publications/elibrary-page/?id=10251
https://aes2.org/publications/elibrary-page/?id=3158
https://aes2.org/publications/elibrary-page/?id=3793
https://aes2.org/publications/elibrary-page/?id=2476 this one is about more than just Intermod
You can easily dream up artificial test signals where a significant part of the population, eg >20%, can detect a 20kHz brickwall filter. In fact, I think someone on this forum effectively did just this with a poll on the audibility of clicks IIRC. I was quite pleased that 20+ yrs as a beach bum in the bush hadn't killed my ears completely. 😊
But the percentage who can do this reliably on music, speech or other 'real life' siignal is MUCH smaller. I'm really ONLY interested in the opinions of this very select group.
Isn't anyone going to post a lossless file of music/speech or other real life signal with huge slew rate demands?
At AES Hamburg 1981, one of Prof Otala's students presented a very good paper detailing his most careful hunt for unicorns with da Professor's zillion V/us slews. Only to prove conclusively that they did not exist 😲
Surely we can do better more than 4 decades later? 😊
As a maker of commercial audio stuff, I want my stuff to be salable rather than accurate of even musical. It's just that IM not so LE, musical, accurate & salable usually go together .. apart from small glitches like 20kHz brickwall filters 😊 ... provided the buyer can listen to my stuff properly.You then need more than 20 kHz of bandwidth if you want the reproduction to be accurate rather than musical.
Today, the buyer has even less chance to hear stuff before buying than in da last Millenium. So "my stuff is hand carved from Unobtainium & solid BS by Virgins" is probably the most important factor 😲
To come back to this. Many years ago I participated in a DBT for audibility of FM multiplex filters, that limit program material to 15kHz.In da previous Millenium, ALL properly conducted DBLTs on bandwidth limiting including mine, showed that of those who could reliably tell the difference, ALL of them preferred a brickwall 20kHz filter.
They level-fall like 80dB in the first octave and have phase shifts of 1000's of degrees at 15kHz (no that's not a typo!).
We were 6 participants, one could'nd hear a difference, the other did, statistically significant, and they ALL preferred the filter in the chain, moi included!
Jan
Just so I don't have to start paying AES dues again, could you briefly summarize a typical number of test subjects, blind protocol (ABX?), any training provided to test subjects, and examples of controls? If that's too much info to keep it brief, would be most interested in protocols used and if any particular test subject training was provided. Thx.I've conducted/been involved in separate DBLTs to investigate several of the aspects you list.
This is a HUGE subject and I could write a book about it.Just so I don't have to start paying AES dues again, could you briefly summarize a typical number of test subjects, blind protocol (ABX?), any training provided to test subjects, and examples of controls? If that's too much info to keep it brief, would be most interested in protocols used and if any particular test subject training was provided.
I do ABC tests rather than ABX cos you get statistical significance MUCH faster. I disagree with some of the Lipshitz & Vanderkooy ABX crowd and da false prophets Toole & Olive on some of their 'protocols'.
eg you don't need to provide any but the most basic training if you let the subject choose his/her own music. If you do this and other stuff, you find the man-in-the-street does as well and usually better than the most rabid audiophool. ie provides more reliable results.
But for the bandwidth limitation tests, only the most perceptive of my A team panel would give reliable results; ie the likes of "Big Ears" B***s and "Bat Ears" F******r" ... so they would be very au fait with the protocols of siuch tests.
For such a test, the ABC test would have 2 presentations the same though you NEVER tell the subjects this or even what they are listening to. As far as they are concerned, they might be listening to 3 different mains cables 😊
I might hint that I expect the differences to be at HF but even that is close to adversely affecting the blind nature of the tests. 😲
- Chip Amps
- Slew rate myths floating around the internet
