Alphasonik PMA-2300 zobel
Are R42 and R142 (picture attached)
Can you take a picture from further away? I'd like to see what type of board revision this is, so I can find it on another board for you.
Edit: A similar amplifier from the same series has 2.2 ohm resistors (red-red-gold-gold, fusible) in series with the PET caps at the outputs. That sounds like an entirely reasonable value to me.
If you don't get any more reliable information, compare the values of the parts in your amp to those in the attached image. The inductor in the output makes this seem like a Zeff design. The attached clarion is also a Zeff design.
In attached board picture
