Hi everyone,
I’m in the early planning phase of a DIY speaker project inspired by the Avantgarde Acoustic Zero 1 XD and Zero iTron. While I don’t intend to clone them directly, I’m fascinated by their compact, active horn design and how they blend traditional horn acoustics with modern electronics.
My goal is to design a 3-way horn loudspeaker that reflects this idea — but with my own twist: a focus on analog signal integrity in the mids and highs, and digitally controlled, active bass using Hypex DSP.
Friedrich
Concept Overview
- 3-way loudspeaker with horn-loaded mid and high
- Passive mid/high crossover
- Active DSP-based bass section
- Frontend:
- Turntable and external DAC
- Pass Aleph P1.7 preamp
- Aleph J Class A amplifier for mid/high
- Bass amp: Hypex FusionAmp FA251 or FA501
Tools & Research (So Far)
I'm currently researching and evaluating tools to simulate and design the horn sections:- Hornresp – for estimating horn behavior and cutoff frequency (F12)
- ATH4 – for modeling OS-SE or Tractrix waveguides and exporting STL for 3D printing
- AkAbak – potentially for system-level simulation (once I’m deeper in)
- Also collecting Excel sheets and online calculators for basic flare geometry and alignment
Tentative Driver Selection
Midrange Horn
- B&C 5MDN38
Tweeter Horn
- BMS 4524 compression driver
Bass
- Considering FaitalPRO 12PR320, B&C 12PS76, or Beyma 12P80Nd
- Enclosure: sealed or reflex
- Powered by Hypex FA251/FA501, using built-in DSP for:
- Low-pass XO (~250 Hz)
- EQ and delay alignment with mid/high section
- Which tools are best for horn simulation at the mid and high frequencies?
- Tips for integrating a hybrid analog/DSP setup without phase or delay issues
Friedrich
Both ways start with the same design, measurement and simulation.. so just begin as you would normally.Tips for integrating a hybrid analog/DSP setup without phase or delay issues
