Transformer primaries out of phase?
Joined 2021
Old brain in need of help.
I just hooked up a new Antek AS2225 and it seems the primaries are out of phase because there's a noticeable hum and it starts to get warm. The secondary voltage seems correct but there's no load connected.
I wired the primaries in parallel, with the two red leads together and the two black leads together. I plan to reverse the leads, but just wondering if I read the diagram wrong or did the manufacturer get the colors wrong?
There are no phasing dots on the transformer's schematic diagram, so it's hard to tell. Seems to me, absent the dots, tying the blacks together and the reds together for 115Vac operation should be the way to go. I'd question the mfr, if that's possible. You might also have a defective, unit, too. An experiment you could try is to energize just one primary winding and read the output voltages. Do the same with just the other primary winding powered. Results should be close to the same using either primary winding. If not, then the transformers has a problem.
Reactions: Ixnay and kevinkr
Don't reverse the leads red-red, black-black is correct, this will essentially be a dead short across the primary windings since the magnet fields will oppose each other and cancel out basically only the DCR of the winding limits the current. The buzzing and heating may be due to residual DC on your AC line. A DC blocker may be in order.
(I have used a lot of Antek transformers in my own projects)
Reactions: Ixnay and UncleMud
I would say dim bulb test first. If you do not have a hard short I would have to ask if the noise is from exceeding the primary voltage.
Another way to test would be connect the black primary wires and leave off one of the red primary wires. With power applied do you still get noise? Also is there any real voltage difference between the red wires??
That's a very good proposal. You should get about twice the mains voltage between the red wires if the polarity is wrong and almost zero times the mains voltage when it is correct.
A DBT setup should be used.
I don't have a DBT but I brought it up slowly with a variac and it was reading about 500mA with no load.
Both primaries measure 4R and the secondaries measure .3 and .4R. Both secondaries measure 27v.
I hooked it up running only one primary and still it buzzed and got warm. Tried it on the second primary and same result.
I'm going to remove it from the chassis and test again. When I bench tested it I didn't have this problem but I had only hooked up one primary at the time.
Reactions: kevinkr
It's always good to learn something new. Maybe this is common knowledge, but I learned that surrounding a toroid with a ground is a bad idea.
I thought the small adjacent toroids were creating some competing magnetic fields and causing the problem, but that was not the case. When I disconnected them from the terminal block the problem persisted. But as soon as I removed the terminal block and bracket going across the top, the problem went away.
Go figure.
  • Thank You
Reactions: Ixnay
If you have an inductance meter you can parallel the primaries and read their inductance. If the coils produce opposing magnetising forces in the core, the inductance will drop. If they help each other, the inductance with two parallelled coils should be equal to the inductance with one coil. This assumes the effect of resistance of the coils is insignificant. The reason for obtaining the same inductance as with one coil, is because two coils connected in parallel is similar to using a thicker wire with more cross sectional area.
You can roughly measure the inductance by using a series filament lamp. The effect of the combined inductance will be a dim bulb if the coils aid each other and a fully bright bulb if the coils oppose each other.
Edit: You appear to have actually created a shorted turn. You need to insulate the bolt or remove the bridge with the terminal strip on top of it. You could also replace the metal strip with a piece of fiberglass PCB material (no copper) - this would be safest long term.
Excitation current with similar transformers IMLE has generally been below 50mA at 120V.
Reactions: Bonsai
