Parallel connection of resistors in the speaker crossover
Hello everyone! Guys, can you tell me if it is possible to parallel resistors with different resistance in the speaker crossover? It is necessary to replace the 3.6 Ohm/10 Watt resistor. I don't have one, but I have two resistors for 12 and 5.1 ohms/5 Watt. Will there be any negative consequences from two different resistances?
By the way, if you build a battery like this, how will the power be distributed?
I'm sorry, I didn't finish drawing the entrance and exit. Will this battery be better than a single 3.6ohm/5 watt resistor? The resistance will be about 3.8 ohms, but I don't think 0.2 ohms can change the sound much.
