A60(+) Amplifier. Build this?
I can understand your point of view, but why would i change, if i never had problem with it? I have hundreds of mica washers...
Hello!
Thanks for all your advices. I do not understand why should I unsolder the connector...I may find a connector that fits.
The left and right pins are in connection, the multimeter beeps....and the pin that is not marked goes to a resistor(like in a stereo to mono converter cable...).
Hello-
If this is not the correct place to post this question please accept my apologies in advance.
I am looking to troubleshoot my A60 amp that I purchased off AliExpress. I have been listening to the amp for the past 4 months and think it is a phenomenal amplifier.
Previously when it worked correctly, I would turn the amp on and I would hear the audio signal turn on through the speakers, after a few seconds. That no longer happens and there is no sound. Previously when I looked into the chassis I would see a dim blue light that I no longer see.
Any help on where I can start to troubleshoot?
Dan
Hello-
Dan
I have ordered a ASS2 the delayed soft start board, and I am going to attempt to replace it.
Reactions: Paroxod4
After turning on the amplifier, measure with a multimeter, does 230 V come from the soft-start board to the primary winding of the transformer? If not, change the soft-start. Is there an additional fuse on the board itself? Detailed photos would not hurt for inspection.
Reactions: Hifi-Dan
