Hello Master Steele!How do I enter t/s parameters like Qes = 0.54 ? The new input screen seems to allow only 0.5 or 0.6...
Double click on the slider. Enter the value you wish, undt voila!
Thanks, but I think I discovered a bug - the calculation of Qts isn't done until one of the sliders is moved...
You have indeed!
Hopefully it can be fixed in the next update, along with adding a dual offset driver transmission line model 🙂.
Just to clarify, it is not essential that the slider be double-clicked.
It is only necessary for it to have the focus - tabbing to it or single-clicking is sufficient:
Data values can still be directly entered if so desired by selecting the relevant slider, keying in the required value and pressing Enter.
You have indeed!
Oooh....!
I'd better start working on that BOXPLAN model for it ....
