Please help me understand the purpose of such a filter at DAC line output
Hi ! It is something about impedance matching or what else ? Capacitors value are so small that my multimeter shows 0.01nF that propably be an error, but it measures values about 5-10nF very well...
But which will be cut off frequency with 10pF in such filter if we assume it is just a filter? Lets think about multimeter error and it may be 5-20pF, but it measures well 510pF cap right now.
Perhaps this is just trick to show exactly 10K at RCA ?
Sorry, my mistake. In original schematics here is additional coupling cap. At the left side here is a circuit to headphones op amp. I use it without coupling caps so show wrong scheme in 1st picture.
In circuit testing of capacitors often results in wrong values because there are too many other components involved that may disturb measurements. But as pointed out already, the low pass filter is to reduce high frequency garbage from the DAC.
It’s an anti aliasing filter. All DACs will (and must) have it.
If you think about a digital, time discrete signal, it will look like a series of steps in the time domain. In the frequency domain, that looks like the entire signal is mirrored about the Nyquist frequency (half the sample frequency). This is obviously not good, as it creates a lot of junk signals.
So you need to insert a filter with a cutoff frequency at about half the sample frequency. In the time domain, it looks like smoothing out the steps to form a continuous signal. In he frequency domain, it looks like getting rid of the mirrored spectrum.
What do you mean by "entire signal mirrored" please ?
The frequency spectrum is mirrored. Let's say you have a 44.1kS/s CD signal. It will have useful frequency components up to half that frequency, i.e. 22050Hz. But if you use the output from the DAC, it will actually have a 44.1kHz bandwidth, but anything above 22kHz will be garbage. More specifically, that range will be a mirror image of the useful part of the spectrum. Here's an example. I Sampled a square wave. You can see all its harmonics. But you can also see the same signal mirrored in the upper part of the spectrum.
Reactions: diyiggy
It may also suppress RFI coming from the output.
to prevent instability of the cable loaded OP, and also a filter of very HF signals, both from the DAC and returned from the cable.
Seems to me this is right point about it.
There is no DC at DAC output, so DC blocking electrolytes to line out are present only for some safety (?) from external DC or mute key burnout protection (?)
only 10pF
yes, this doesn't look like a usual RC-filter
Is the schema complete all the way to the output terminals?
like post #4, only the mute key is not drawn.
There could very well be DC on the output of a DAC. Just feed it a string of max level and you have DC. I know, because I accidentally did that once… So if you have a faulty bit stream, you could certainly see DC.
