Yet another "opamp + transistor" SE headphone amplifier
Not sure that it actually needs the servo, but I was not happy with 18mV worst case DC offset at the output.
Seems to simulate pretty well.
If you decrease the value of R2 the output offset will also decrease. Try 100nF 270k for hp filter. If the filtering is set too low, it will cause slow transients, excessive bass, and the overall sound will lack tightness and feel sluggish. The current generator can be replaced with 100R 5W resistor.
Thank you, that would be the case with a bipolar opamp, but with FET opamps the gate current of the input stage is so small (in the femto-ampere range) that the value of this resistor can be arbitrarily large without really affecting the offset.
Unfortunately, that would reduce the output transistor's ability to sink current.
