Hello everyone I have bought Qcc5125 module . can I use this module as a transmitter,if so can anyone suggest me how to do that. How do I connect with another bluetooth module
Hello Shadowfire and welcome!
Could you point to the exact item you bought?
I suspect the qcc5125 is a bluetooth reciever only. So it may no be able to transmit sound.
https://www.qualcomm.com/products/internet-of-things/consumer/audio/qcc51xx-series/qcc5125
There seems to be a relay on the board. This usually disconnects the analog external input from the output whenever there is an active bluetooth connection. I don't think this board can transmit via bluetooth.this board has audio input pins
Thank you for your response stv , could you suggest any qualcomm or any other modules that can transmit audio.There are less options in india . I ordered this from china thinking it could transmitter audio via bluetooth.Any qcc higher version supports audio transmission.
No, I would just do a google search and it's better if you do it yourself.could you suggest
You know better what you need!
It can function as a transmitter, but only with custom firmware and the appropriate software support from Qualcomm.Hello everyone I have bought Qcc5125 module . can I use this module as a transmitter,if so can anyone suggest me how to do that. How do I connect with another bluetooth module
Thankyou guys for supporting. Can someone share QCC5125.Xuv file to brun from NVS
Thanks in advance
Thanks in advance
- Member Areas
- Introductions
- QCC5125 based soundbar
