Dear all.
I am searching the best open baffle woofer with alnico.
It has to be fast. The Lii Audio W15 is to slow.
What is the best JBL woofer for open baffle? Maybe the K151?
Or do you know one another woofer? Maybe Gauss, Celestion, Tesla or Lomo Kinap?
I listen often Electronic Music..
I am thankful for every recommendation
regards Daniel
regards Daniel
I suggest to read this paper: https://adireaudio.com/wp-content/uploads/2018/12/Adire-Audio-Woofer-Speed-by-Dan-Wiggins.pdf
Assuming you are going to use a crossover or equalizer to shape the frequency response, all woofers are equally fast.
A second point: measure the systems frequency response at your listening position. Room modes will screw it up and make the sound boomy and 'slow'. If you equalize the bass range to be flat at the listening position, the sound will be 'faster'.
Thank you. To look for the induction "Le" i dont know know before.I suggest to read this paper: https://adireaudio.com/wp-content/uploads/2018/12/Adire-Audio-Woofer-Speed-by-Dan-Wiggins.pdf
What is about the "qts"?
People say 0,6 - 0,7 is good but is this really important? My Baffle size will be 70cm wide and has 30cm wings.
If you are going to use a Digital Sound Processor (DSP), then the Qts is not that important. A high Qts driver might need less voltage in order to reach its excursion limit in an open baffle. That is no problem because amplifier power is cheap.
"Le" is something to look for but more in the context of harmonic distortion. Low distortion drivers have shorting rings, which most manufacturers state in the data sheet. Be cautious for cheap (without shorting rings) woofers with a high value for "Le", as these tend to have more inductance-related distortion. For more information, take a look at this poster: https://www.klippel.de/fileadmin/_migrated/content_uploads/Klippel_Nonlinearity_Poster.pdf
Hello,
Coud you say on this illustation where do you find your loudspeaker slow please ?
Inductance also has a substantial effect on IMD (intermodulation distortion), which won't show up in any kind of distortion plot. The lower and more linear the inductance is, the better time domain performance it will have which will yield better IMD performance. This is interpreted as "transient response" to most people.If you are going to use a Digital Sound Processor (DSP), then the Qts is not that important. A high Qts driver might need less voltage in order to reach its excursion limit in an open baffle. That is no problem because amplifier power is cheap.
- Subwoofers
- Open baffle woofer
