Mission 700 series baffle vibration
I have a pair of Mission 701s where the plastic front baffle vibrates against the wooden cabinet because the glue has failed. Apparently this is a common problem but I cannot find a good fix.
Any ideas?
If nobody can think of a better plan I'm going to try using an excessive amount of PVA over 4 days.
(1) Remove the woofer.
(2) Run a healthy bead of PVA along a long side of the baffle on the inside.
(3) Leave the cabinet face down (at a slight angle) to dry overnight.
(4) Repeat the procedure on the other 3 sides.
Will that work?
Okay, so it worked on the first one. I've only glued to the long sides. Even though the other one doesn't have the problem (yet). I'd thought I'd use it to document the repair.
Sorry about the quality of the pics.
