Assistance with Reverse Engineering Crossover
Hello,
I’m looking for assistance with reverse engineering the crossover network from a pair of speakers. Specifically, I would like to know if it’s possible to create an accurate schematic based on detailed photos of the crossover components and layout. There aren't schematics available online, sadly.
If feasible, I’m happy to provide high-resolution images of the crossover board, including close-ups of the components and their connections. The goal is to document or potentially replicate the design for analysis or restoration purposes.
Any guidance or support in interpreting the layout and developing a schematic would be greatly appreciated.
Best regards,
Michael
It might be possible.
An experienced designer will probably see what topology is used and can figure out the most likely configuration.
Lets give it a shot...
If its a current model of a commercial loudspeaker I would avoid helping you so please let us know what speaker it is.
It’s an older Boston Acoustics speaker from 1999. The VR-M60.
The crossover for those two-way speakers shouldn't be too difficult to work out. It will be interesting to see how many components it contains. The manufacturer's specifications from 1999 for the VR-M60 state that the crossover frequency is 2500 Hz, although another document states that it is 2700 Hz. These speakers also had provision for bi-amping.
So the VR-M60 XO point is 2500hz according to the manual. The smaller brother VR-M50 XO point is 2700hz. I believe this might be what you’re referring to.
Reactions: witwald
Hello,
Best regards,
Michael
Why do you want to do this?
If you have a mic, measure the individual driver responses, and attempt a x-over either in a sim or for real. Then look at how they did it, and see if they took any shortcuts that you might not. There's a hundred ways to do a speaker x-over. Odds are high that they went with one of the lower cost options, since profit is important for staying in business. Higher cost does not necessarily mean better, but sometimes a better x-over may sound pretty much the same as the cheap one to 8 people out of 10. The people that hear a difference might be willing to pay extra for it, but some may not.
All done here:
Is this your measurement? Was it on a stand, and away from walls, etc?
Measurements posted by a user on ASR: Details below
"I thought this group would be interested in how some vintage speakers compare to each other under the same measuring conditions. I have a collection of vintage speakers and simple measuring setup. No Klippel machine for me! I measured the frequency response of each speaker with:
  • Laptop PC with Creative soundcard
  • REW software
  • Dayton UMM-6 microphone, with calibration loaded in REW
  • Random Denon amplifier
  • 1 meter distance, on the tweeter axis
  • 20x24 garage with hard floor and 9.5' ceiling
  • Small amount of damping on the floor
All of the measurement suffer from a floor bounce dip at ~80-90hz depending on the height of the woofer and mic. Sorry about that.
Here's the setup."
