SMD resisters
Can anybody recommend surface mount resisters that are non-magnetic and very high quality, suitable for feedback circuits and high gain areas like phono stage ? I've got loads of choice from the basic to the ludicrous in through hole, but I don't see the same choice in SMD.
First ones I'm looking for are to bias op amp into class A, currently have through hole resisters soldered into an 8 pin socket, which despite being small, are still too large and I thought SMD would be a good replacement.
I've read a lot of people denigrating SMD for audio, but there must be some devices which are suitable, low inductance, low noise, non-magnetic etc. All DACs and streamers use SMD and some of the DACs I've heard sound very fine indeed, I just need to understand what's available.
Thanks, I got a handful of values of Holsworthy TE Connectivity resisters, they are 0.1% 10ppm/*C, don't need quite that tolerance but won't hurt and seemed a good place to start, I'm not Atari buying in millions, just 10 of each value. I'll look out for Susumu next time.
Yes, a temperature-controlled soldering iron is pretty much a requirement these days. Over hot irons tend to damage the PCB laminate as well.
You have more chance to damage your pcb when your iron is not hot enough and you need to heat too long.
This "only just above melting point of the solder" if fine for oven or reflow soldering because the whole pcb and components are heated (with a large heat source) to that temperature.
Btw, thin film, thick film resistors, you won't hear the difference anyway. If someone says otherwise then he's a member of the audiophoolery club. 😉
/me waiting for sticks and stones thrown at me 😁
I have noticed a difference in a pre-amp between carbon and metal film, through hole. No idea if that difference will exist in SMD, comparing 50+ year old tech with probably 10 year old SMD technology, no idea, will have to experiment.
Use SMD thinfilm resistors, not thickfilm.... As small as you feel like soldering, size 1206 is easy, 0402 is hard..... I use Susumu resistors a lot, only good experience. Get a good temperature controlled soldering iron with a small tip. Get a magnifying lamp with LED lightning. A heat gun is good for desoldering. Use thin solder, like 0.3mm dia, for diy use lead/tin solder.
Just a little longer than 10 years, SMD resistors have been around since the early 1980's.
Very true, however from an engineering perspective don't use thick film resistors in the feedback path of a power amplifier, there can be measurable differences in distortion.
They've arrived. Photo on the label from Farnell. Nano SIM on the right for size. The SMD resistors (o 🙂 ) are the four little black rectangles below the four dots on the white strip. They must have to employ young people to make these, nobody over the age of 30 will ever see these with the naked eye !
Those are 0603 size, that is LARGE (in current production environments) 😱 0603 is about the smallest I use in manual soldering like pull-ups and 100n decoupling. But industry is already past that for years. When I was still designing electronics for a living 0603 was the goto size (except large capacitors), passives in digital were typically 0402. And for phones 01005 was becoming usual.
Reactions: SteveVulture
