TAD/Exclusive 2402 Inspired Build
Hi All,
I recently took the plunge on a pair of TAD 1601a woofers and the TH-4001 horn that popped up for a good price. So now I find myself committed to a build..
It's always been a dream to replicate the exclusive 2402, but purchasing the TD-4001 drivers is out of reach right now. I was considering a pair of JBL 2450H's, as I've seen them recommended here as a good match for the TH-4001?
I plan to go active, with a digital crossover via minidsp flex. I have an Elekit tu-8900 for the horn. And an Amp Camp amp for the woofers at the moment- I realise this is probably a bit underpowered, but have to work with what I've got until I can buy or build something with a bit more grunt. To compensate for this, I planned to cross the woofers at 80hz or so to a ported Rythmik 12" sub I have.
I was thinking of crossing horns at about 600hz. Tips on crossover for this combo also appreciated.
Frying the compression drivers is probably my biggest fear with the digital crossover, so was thinking 33 or 47µF film capacitor in series - need some advice on this especially.
Eventually I'd like to build full size cabinets in the style of the originals, but for the time being (due to space constraints and the amp/sub situation above) I was thinking of building a temporary 120 litre sealed cabs for testing, since I'll not be asking too much in the bass department of 1601a's.
Anyway just thought I'd put this out to the brains trust for some opinions on the approach and any considerations I may have missed. Realise there is a lot to learn/consider so not in any rush, and flexible with the plan, these are moreso just initial thoughts. Thanks in advance!
The TH-4001 has a minimum dimension of 24cm. Polars would confirm whether crossing below 2kHz is suitable for your configuration.
When you use a capacitor close to the crossover frequency, there are benefits to keeping it installed for the measurement set used to create a crossover for it. That's not to say you might not choose to measure without it while doing your initial acoustic assessment.
Reactions: Arez and jack_
Hi @AllenB
Thanks very much for the reply. Good point, I'll do some polars to confirm, but was thinking around there would be a good starting point if I'm shooting for a similar result to the original design? Although I'm not using the TD-4001, so not sure how significantly differently another compression driver would behave.
That's a good tip re: keeping the capacitor in place when designing the crossover. I'll most likely just leave it in until I'm more comfortable with the setup - it's a bit too easy to accidentally switch crossover presets with the remote on the minidsp..
Thanks @marco_gea , I picked one up yesterday - I think it was actually your original posts I was referencing for the recommendation.
Thanks for the tip on the diaphragm. I'll try the originals for a bit and see how they go - but it's great to have an upgrade path. I saw they have a Beryllium version too, but the only price I could find was $1200usd a pop - at which point it probably makes more sense to pick up a pair of td-4001's..!
What crossover parameters did you settle on if you don't mind sharing? Anything to watch out for in your experience? Could be handy to use as a starting point.
Thanks again
Reactions: berndt
Having various diaphragm options is one of the pluses of the JBL large-format drivers.
As to crossovers, I tried many configurations, passive, analogue active and DSP.
I "settled" for a relatively humble but satisfactory DBX analogue active unit, 24dB/oct LR, with front-to-back offset adjusted to obtain phase match at Fx.
Reactions: jack_ and Arez
I played around with some simulations in Winisd to maybe help you understand what can be expected from TL-1601a.
I also included a pair of simulations with it's successor TL-1601b that is better suited for a ported design.
I think TL-1601a can be used in a ported design, but would better of in a passive radiator system or in a sealed enclosed with a sub as you are planning.
All these simulation have the gain of a 30 m2 room added so this is estimated in-room responses.
Ranged from the top at the 30Hz vertical line:
Dark blue: TL-1601a in 105 liter ported enclosure.
Light green: TL-1601b in 97 liter ported enclosure
Red: TL-1601b in 92 liter ported enclosure
Purple: TL-1601a in 120 liter sealed box
Dark green: TL-1601a in 60 liter sealed box
Personally I would select 60 before 120 liter sealed box when combining with a sub.
You will exite less room resonances and get a little peak at 100-200 Hz that will help to compensate for the dip that often occur in 100-200 Hz because of floor reflection if bass driver are placed with some distance above the floor. I assume you want to do that to not have a too low position of midrange in the soundstage.
Yes, obviously putting a rather "fragile" driver in a tiny closed box ,and applying some EQ boost to feed it some more power, is probably the best solution for it. Especially as it's problems with heat buildup and demagnetization is so widely known.
There is no chance that someone like Kinoshita who built a large number of monitors with them, and worked on the development along with Locanthi would know how to better use them. Or TAD's research and development lab.
The TL-1601B (and 1603 even more so), is the direct result of needing more thermal capability in the drivers to avoid the issue.
That is why you find fx. vented VC former, and vented motor structure under the spider on the 1601B/1603.
If you do so do be mindful of what kind of power you put into the drivers over long sessions.
Reactions: marco_gea
