Why is the MMS so far off?
So either this data is junk or Dayton woofers are REALLY off spec. I am inclined to believe either as I've both messed up measurements and had Dayton woofers that measured no where close to their specs.
I took impedence measurements of 3 of woofers (should have been 4 but one arrived damaged). They all measured nearly identically. I measured these exactly the same as I have measured every other woofer I have ever used. Unless I royally screwed something up. I'll even zip the impedence measurements and toss them on here.
The one spec I find the most concerning is the MMS. They have listed 24.17 grams. I show 16.27 grams. Way off. I used 12.08 grams of blue tack and added that to the cone for my measurement. That should have been half of the MMS. If the MMS is actually 24.17 grams.
Can anyone see errors in my measurements here? Or is this just what it is?
I might just buy a DATS V3 just so I can always be sure. Thoughts on how good those units are? Pretty reliable?
  • Dayton Zip.zip
    Dayton Zip.zip
Measurements usually give a conistent set of parameters that will provide very similar enclosure simulations to data sheet or other measurements, even if the parameters themseves vary. That's usually no problem.
Did you loosen up the suspension prior to measurement?
Have a look at this driver test and the (apparent) parameter deviation:
https://hificompass.com/en/reviews/seas-excel-6-w18nx003-e0096-08-midwoofer-review
Make sure to click on the hidden paragraph "Broken-in and measurements of Thiele-Small parameters by other manufacturers"!
Reactions: Arez and Bmsluite
The measurements are quite noisy, that could be one source of error in T/S determination. Added mass is barely managing 25% drop in Fs, I would use a bit more added mass personally. You should also start your measurement sweep at 0Hz, not 20Hz, there's a lot of missing information that REW is trying to fill in with a curve fitting algorithm.
Comparison to datasheet is inconsequential - datasheets are often wrong. Comparison to actual result when the driver is placed in a cabinet is what matters.
FWIW, in ignorance chose to add between 1.44 - 1.56x and always got the predicted results close enough for me and the intended owner:
Pg. 76: https://archive.org/details/HowToBuildSpeakerEnclosuresByAlexixBadmaieffDonDavis/page/n75/mode/2up
“A nagging question in the design stage of any enclosure of this type is "How large shall it be?” It was pointed out earlier that the enclosure can be too large or too small for proper bass-reflex action. This implies that an optimum volume exists and indeed it does. This optimum volume does not depend upon the size of the speaker nor its resonant frequency per se but rather on the ratio of enclosure air stiffness to the speaker cone suspension stiffness. This optimum ratio is 1.44 or, looking at it another way, the speaker resonant frequency in the enclosure before porting should be 1.56 times the free-air resonance of the speaker. This size enclosure, when properly tuned, yields at the same time the most extended low-frequency response and a transient response with subjectively unnoticeable hangover, assuming sufficient damping exists. Compared to the entirely closed cabinet, the half-power point (3 db down) occurs at 0.7 times the closed cabinet speaker resonance for an extension of one-half octave."
Mms is cross calculated with Mmd and.....Mdl
So I am sure Dayton knows the moving mass of the parts and far as Mdl radiation mass of air load.
Im sure is susceptible to all kinds of errors to home measurements.
I have sum checked and entered likely every driver Dayton makes in virtuix or WinIsd
WinIsd has sum check error when you enter data. If any conflictions it tells you right away
and wont let you save the driver. And will tell you what parameters have conflictions.
I have never had any sum check or glaring errors with any Dayton drivers.
So hardly doubt their T/S parameters are wrong.
Actually had way way more errors with more " expensive" drivers
Just enter DS175 into sim and press calculate.
Magnet is extremely powerful with Low Qts. Without simulating 9 out of 10 guesses
will be it is a 4th order alignment. So either BB4 or C4 hit calculate and done.
