Free Stuff in Victoria BC
Frugal-phile™/Moderator
Joined 2001
Landord has made it untenable for me to keep this stuff so it is all free … but you have to come pick it up.
A bunch of working vintahe drivers, a set of Maeshowe horns (sans drivers), Hawkford Memorial Monolith (sans drivers), A attempt at an MI speaker with rebuilt vintage Stromberg Karlson PP tube amp and a Philips 12” FR in cabinet (could use a tweeter — lots suitable).
Will add items as i come across inventory and pictures as i can take them.
It will be here for about 2 weeks and then anything left goes to 1-800-Junk which would be sad.
UltraTouch, and a lot of bits.
Some stuff not quite as time critical, ie a couple woofer projects and a nicely finished set of Trapezoid ML-TLs with push-push EL-166eN.
I am also blowing out a lot of new drivers cheap:
dave
I keep digging up more.
A left/right pair of the Akai/Roberts R-R amplifier modules from the R-R. Basically remove parts and rewire with new passive parts where needed. At least acouplethreads here.
If you need a set of mono loudspeakers, just dug out a nice vintage R&A 6.5” FR.
And if you want something to plug into the AC to see what happens, somecandidates for that. Some initial pictures.
The next 2 have been crudely retouched to remove items not for give away:
dave
Reactions: silverD
Found 2 more totes of drivers:
The 5 9” Eastechs went nbetween this pic and now. Nice 10” Corals but for a slight crease on one cone.
In this one the “pairs” of Philips drivers are just the same size. And a pair of Wharfdale Super 8 amonst the lot.
dave
Making progress getting everything out.
2 pr Zenith Allegro 8” woofers (1 sans dustcap)
A bunch of Isophon Alnicos. Suited for Open Baffles — easy to imagine a stack of the 3 6.5” each side. In the bottom right hand corner are 2 Philips and a pair of2.5” Aura (EnABLed)
dave
This side is largely populated… totes have drivers in them. Tall speakers are Hawking Memorial MonoLiths … probably $500 of meterial in these. And the red ones were intened to be Audio Note kits, comes with 5 or 6 Coral woofers they are rebated for, and a 3” FR (intended for TB W3-971… if i can find them i have an EnABLed pair can go with. The vintage Stromberg (was rebuilt and working last time it was fired up) is sitting on topofthe accompanying vinatge cabinet with 12” Philips whizzer cone FR… EnABLed. Needs a tweeter, got lots. Mission subwoofer with working 8” and dead amplifier (in their carboard box)
And a preview of the other side. A bunch more drivers added, The 4 Sansui Alnico 8s, and 3” FE83A are mine but someone might talk me out of them. The 12” Wharfedale sitting on the Thorens DD has a stiff surround, if no-one wants it i will harvesythe magnet. Piano in behind is up for grabs too. The b3 totes are full of records… 3 more boxes in hiding. Mostly Classical.
dave
